96 blazer miss
Old Feb 8, 2009 | 11:36 PM
Beckyj636's Avatar
Beckyj636 is an unknown quantity at this point
Default 96 blazer miss
it a 4.3 the cap and rotor are good It looks like the wires ans plugs were changed not to long ago, But I get like 6 mile to the gallon.. I want to check the timing , any wire to disconnect to stop the computer from adjusting the timing? any ideas what to check for poor mileage and the miss?
Old Feb 11, 2009 | 02:28 PM
travtug321's Avatar
travtug321 is an unknown quantity at this point
Default RE: 96 blazer miss
fuel pressure 60 -62 psi
plugs
intake gasket
Old Feb 11, 2009 | 03:58 PM
96Blazernut's Avatar
96Blazernut is an unknown quantity at this point
Check the firing order on the engine, it's easy to get them confused
Old Feb 11, 2009 | 06:52 PM
Beckyj636's Avatar
whats the firing order on this truck?
Old Feb 11, 2009 | 08:29 PM
165432
Old Feb 11, 2009 | 08:38 PM
BudRacing's Avatar
BudRacing is an unknown quantity at this point
Pull one or more of your plugs to check for fouling. At 6 mpg I'm surprised you're not throwing a code. Even though you say the cap n rotor are good, take the cap off and clean the contact points. It's easy and can only help.
Old Feb 11, 2009 | 09:09 PM
Beckyj636's Avatar
I took they off the pins arnt rounded or black just a bit white. I replaced a vacuum line going to the vacuum ball on the hood I have received 100 mile on just 1/2 tank of fuel as of this time. I need to get a diagram of the engine for what cylinders are what number.
Old Feb 11, 2009 | 09:11 PM
BudRacing's Avatar
The top of the cap is probably numbered. It should be in order like that.
Old Feb 11, 2009 | 09:50 PM
Beckyj636's Avatar
i mean the engine I forgot what cylinder is 1 2 4 5 6
Old Feb 11, 2009 | 10:53 PM
BudRacing's Avatar
The engine should be in the same order as the cap is.
