96 blazer not much hair left from pulling it out
Old Mar 10, 2013 | 06:05 PM
stan kelly's Avatar
stan kelly is on a distinguished road
Default 96 blazer not much hair left from pulling it out
this is the problem. will not start even with starter fluid. I believe it's the ecm but not sure. This is what was done so far. injctors spider replaced, new battery, new spark plugs, fuel pressure 60 psi. I tried to check the pulse but not sure I was doing it corectly. removed harness from the top of the injectors pink wire to ground key on ligh stayed on all pink wires to ground. I was thinking it should pulse. I do have spark to the plugs. or I have ony checked one and it did have spark wile cranking.. Any help would be great thanks
Skitzoape
Mar 1, 2014 01:56 PM
boisewayblazer
Apr 19, 2011 12:14 PM
BlackFireLS4.3
Jan 29, 2010 10:00 PM
noyb72
May 12, 2008 10:48 PM
gareth12
Oct 11, 2007 08:17 AM
