96 blazer starting problems
Old May 29, 2008 | 04:32 PM
baken20's Avatar
baken20 is an unknown quantity at this point
Default 96 blazer starting problems
It started having diffeculty starting about a week ago. Has been running with a miss until it warmed up. Now it won't start-just cranks with an occasional sputter. fuel pump turns on with key. Pressure when cold is 49, then slowly loses 3 or 4 pounds over 10 - 15 minutes. If i put gas in the throttle body it starts - and will continue to start unless i let itsit for awhile.When it starts pressure flutters between 50 & 54. when i turn it off and turn the key pressure is at 54 - 56. any ideas ???????? Thinking fuel pump, but don't want to find out after that it isn't...
Old Jun 3, 2008 | 03:39 PM
Psychropod's Avatar
Psychropod is an unknown quantity at this point
Default RE: 96 blazer starting problems
It's definitely the fuel pump. Pressure should be at 55-61 psi at crankup. Once the engine cranks, pressure can be lower to sustain the engine, but it definitely should be much higher than that.
Sorry, dude...you gotta drop that tank! [:@]
The good news is that if you run a search, you'll find that a lot of people here have done it already, including myself.
Old Jun 3, 2008 | 05:03 PM
baken20's Avatar
Yeah -- changed fuel pump. Been starting ok. Still runs with hesitation until it warms up??? SES code is evap code. Any ideas why it is running this way?
cgrett
Nov 15, 2010 09:08 PM
Bootyjones
Feb 9, 2010 06:09 PM
upblazer95
Apr 4, 2009 08:27 PM
Sprocket
Mar 20, 2008 09:39 PM
Dean S
Jan 30, 2006 02:51 AM
