96 blazer won't run with ac delco double platinum plugs?!?!
Old Nov 7, 2011 | 01:30 PM
Plasmatic's Avatar
Plasmatic is on a distinguished road
Default 96 blazer won't run with ac delco double platinum plugs?!?!
I have a 96 blazer, and can't figure this out. It runs rough and is hard starting when it's wet out, but otherwise runs decently. I recently purchased the ac delco double platinum plugs and threw them in, and couldn't start it. I pulled them back out and they were wet. Blew out each cylinder with compressed air and reinstalled a few times same thing. I felt like I was banging my head against a wall.
Today I grabbed my spark plug sand blaster and cleaned up the old mix of plugs. 4 ngk, an autolite, and a ac delco rapidfire behind the steering rod. It started right away but runs rough under load (brake stand in garage) no codes set.
Any ideas?
Old Nov 7, 2011 | 01:34 PM
How are the wires, cap, & rotor? Plugs are just one part of a proper tune up.
Old Nov 7, 2011 | 01:48 PM
Plasmatic's Avatar
Cap and rotor is fine, wires were new a year ago.
Just ran it again after replacing the drivers side plugs, then replaced the passenger side and ran again. fuel pressure is at a steady 55 lbs when running.
The old plugs were filthy after a few minutes. black deposits.
Old Nov 7, 2011 | 01:58 PM
Define "fine"? How old are the cap & rotor? What brand are they?
All of your symptoms seem to point to an ignition system problem.
These trucks really do seem to prefer AC Delco ignition components (cap, rotor, & plugs specifically).
Old Nov 8, 2011 | 02:12 AM
Plasmatic's Avatar
Cap and rotor look brand new. No tracking, cracks, corrosion, etc. It's raining now so we'll see how she does in the morning.
Old Nov 8, 2011 | 04:32 PM
step66's Avatar
I have never experienced the AC/Delco "like" for any of my GM vehicles,especially my jimmys! Running Bosch plats now 30K+ and NAPA/Echlin wires,cap & rotor-no issues! I do find that if one does not use dialetric grease at all connections the usual force needed to remove the wires will result in a fail even in top quality wires! Hmmm,but I DO notice that all my 4.3s prefer Valvoline oil & Purolator Golds...
phxjosh
15
Jul 18, 2018 11:16 AM
s10machine
Jul 13, 2014 08:58 PM
Dadatone
Aug 24, 2012 09:10 PM
bigdaddykane93
Nov 12, 2011 01:05 PM
rastoma
Nov 21, 2009 06:29 PM
