96 Chev Blazer: no power to fuel pump?
If you poke around under the hood on the drivers side near the fire wall in the area under where the vacuum ball is located you should find a RED wire with a quick connect electrical fitting all by it's lonesome (not connected to anything). This wire is a direct connection to the fuel pump. I've put a spade connector in the fitting and put 12V direct to the pump to test if the pump is working (you should be able to hear the pump spin up, or have someone else listen for it). That'll tell you if the pump is working and that you don't have a broken wire to the pump.
Powering up the pump from here is also very convenient if you have to drain a fuel tank. Disconnect the fuel delivery line from the pump, put a rubber hose on the pump fitting and pump the fuel into a collection tank. I did my fuel pump replacement this way with a full tank of gas and pumped my tank dry in about 15 minutes.
Good luck with figuring out your problem.
762mm
Mar 28, 2021 01:54 PM
insanefirewall
13
Mar 16, 2011 12:18 PM
walisha
Nov 3, 2009 07:13 AM
Stng5pnt8
Dec 29, 2008 07:36 PM
kc2iyh
Oct 23, 2007 02:14 AM
