96BlazerOKC
Old Sep 23, 2010 | 05:50 PM
96BlazerOKC's Avatar
96BlazerOKC is on a distinguished road
Default 96BlazerOKC
I just bought a 1996 Blazer LT awd ,4.3 vortek , 4-speed column shift,when you first start it , it runs well then after 8 miles of driving you give it gas & nothing.So if you put it in park turn ignition off & re-start it,put in gear runs good again.Fuel pump pressures up,changed fuel filter ,alot of pressure there & at the fuel rail also,check engine light does not come on & autozone came up with no trouble codes.Can anyone help me with this matter?
Old Sep 23, 2010 | 09:53 PM
DKSDAD's Avatar
Welcome to the forum from New York!
Old Sep 23, 2010 | 09:54 PM
wlorton's Avatar
Welcome!
Old Sep 23, 2010 | 10:21 PM
rriddle3's Avatar
*The 'New Member Area' is not for asking technical questions. Moved to '2nd Gen Tech'*
Old Sep 23, 2010 | 11:40 PM
iloveblazers's Avatar
iloveblazers is on a distinguished road
sounds like you have a problem with the air getting to the engine. Have you cleaned/replaced your air filter yet?
Edit: have you checked the coolant level? Or maybe it could be your water pump?
