97 4.3 W revs too high when started!
Old Dec 12, 2011 | 05:06 PM
step66's Avatar
Default 97 4.3 W revs too high when started!
Does the motor need 2000rpm @ initial start in cold weather?I replaced the TPS last summer,and it seems that this is too hard on a gas motor @ 8*C As I hear an immediate rod knock-which goes away in 30 secondsOne should not have to ruin their units engine just to warm it up excessively!TPS or elsewhere? Ideas?
Old Dec 12, 2011 | 05:35 PM
trucktom's Avatar
trucktom is on a distinguished road
codes? idle air control solenoid on the throttle body or a bad vacume leak
Old Dec 13, 2011 | 03:41 AM
step66's Avatar
No codes-No bad vacuum leak evident after a cursory glance,so maybe the IAC. But issue only happens when starting from stone cold and then unit runs & performs fine. Unit is stock with 180K.
Old Dec 14, 2011 | 05:16 PM
step66's Avatar
It was the IAC! Or at least it seemed to be as the problem is no more. But why no CEL or codes? I did disconnect the battery during the swap and the CEL comes on at start as normal-then goes out...I guess I'm good for now...
mansopoor
Feb 27, 2011 04:58 PM
dachiphunter
Aug 4, 2009 05:16 AM
LovemyBlazer95
Jul 24, 2009 11:24 PM
soldierboy7
Jul 14, 2009 08:44 PM
DWreck
Jul 11, 2009 05:57 PM
