97 Blazer 4x4 ls 4 door
Old Nov 23, 2011 | 11:17 AM
d1v3r's Avatar
d1v3r is on a distinguished road
Default 97 Blazer 4x4 ls 4 door
I have a blazer that wont start it fires and will idle for about 10 seconds and then dies. then it will do the same thing for about 4 to 5 tries and then nothin. I have changed all relays,plugs wires, fuel filter, fuel pressure regulator, crank shaft sensor, fuel pump runs fine not sure where to go from here.....most of the info i have gathered from here is that it may be the fuel pump.....any other ideas would be Great.....
Thanks
d1v3r 'aka' John
Old Nov 23, 2011 | 12:09 PM
The dying after 10 seconds is typical of a passlock shutdown on the '98+ trucks. I'm not sure if the '96-'97 have the same type of system, but this type of problem is typically caused by ignition system problems on the newer models.
But I would start with a fuel pressure test. Just saying that the 'pump runs fine' is no indication of whether it actually is putting out the proper pressure or not. The engine requires >55psi to run properly. If the pressure is dropping after the engine is started and dips below 55psi, then it could indicate a restricted fuel supply line or a weak pump.
Athlon2012
Dec 16, 2014 11:35 PM
hlaverty06
Mar 23, 2014 09:25 AM
Guardian1014
Jul 11, 2012 03:31 PM
MowJo
Aug 13, 2008 08:52 AM
dropd4door
Feb 10, 2006 02:34 PM
