97 blazer barely runs.... halp
Old Nov 19, 2013 | 06:39 PM
corradovrt's Avatar
corradovrt is on a distinguished road
Originally Posted by Captain Hook
Next step is check maximum pump output pressure and leakdown at the fuel filter. This will tell if the pump is able to supply adequate pressure, and hold it. If it fails one or both tests, the pump needs replacement. If it passes both tests, the most likely problem is the fuel pressure regulator.
You'll need one of these: Dorman - OE Solutions Steel Body Fuel Line Connector 3/8 Inch 800-121: You= This will connect to the fuel filter, then use fuel injection rated rubber line and connect it to a gauge like this: Fuelab 71501 Fuel Pressure Gauge, 0-120 PSI - Speedway Motors, America's Oldest Speed Shop
All fuel pressure and flow must end at the gauge, with no leaks. Make sure the fuel filter is not restricted. Activate the pump and the pressure must be 73psi to 108psi, while the pump is running. It must remain above 55psi for at least 10 minutes after the pump shuts off. Post your results.
thanks so much man. i really really appreciate it. i will check it in the next couple days, car isnt at my house so ive gotta get there when i can
fnbutch
Jun 25, 2013 12:08 AM
xul
Aug 14, 2011 04:57 PM
UndeadPrincess
Jan 28, 2011 11:25 PM
couve chevy
Jun 15, 2010 07:51 AM
Alex01tib
Oct 12, 2006 04:47 PM
