97 Blazer LT replaced brake booster, won't go in gear now
Old Oct 22, 2017 | 07:49 PM
sgt709's Avatar
sgt709 is on a distinguished road
Default 97 Blazer LT replaced brake booster, won't go in gear now
1997 Blazer LT replaced the brake booster after it sat for about three months. It was parked on a slight incline with the rear lower than the front. After reassembling everything the shifter moves through all the gears but transmission won't engage. Every gear except Park is like neutral. Put it in neutral and it did roll backward when pushed out of rut. Any ideas where to start?
Old Oct 23, 2017 | 09:10 PM
jck1961's Avatar
jck1961 is an unknown quantity at this point
Have you checked the trans fluid level? It's possible that the seal between the transmission is bad and allowed the trans fluid to leak into the transfer case. Sitting in the position you described could allow enough to leak out to keep it from engaging.
Old Oct 24, 2017 | 07:46 AM
LannyL81's Avatar
Also check the shift cable at the transmission...just to be sure that it is intact.
jck1961 is likely on the right path; if the fluid did not leak out, could just be that the trans fluid is at the rear of the pan and little in the trans pump. May have to pull the Blazer to level ground.
Old Oct 24, 2017 | 12:51 PM
sgt709's Avatar
Thanks jck1961 that's what it appears to be. I feel silly for not checking that first, but after adding transmission fluid it works. Thanks for both replies.
Old Oct 24, 2017 | 09:11 PM
jck1961's Avatar
Glad I could help ! You'll need to drain the extra fluid from the transfer case or it will get sucked into the vacuum lines and cause more problems. Just remove the fill plug and have a large pan ready.
TheDevilsDaddy
Aug 7, 2015 06:30 PM
Sandman_3
Sep 18, 2011 01:21 PM
drew_fur
Jun 8, 2011 03:52 AM
95Jimmy
Oct 4, 2009 07:21 PM
96Ls4Dr
Feb 20, 2007 03:28 PM
