97 Blazer trans fluid leak
Old Oct 22, 2012 | 03:59 PM
newguy's Avatar
Is there threads in it? if so there`s your problem. Get a drain plug bolt and 4-5 quarts of fluid and your back in business. Or some how you punched a hole in your pan and need a new pan. Still cheap and easy
Old Oct 22, 2012 | 04:37 PM
That is a dimple to hold the magnet in place inside the pan. Wipe it off and see if that's where it's leaking. If that's it, the pan has rusted through and needs a new pan.
EDIT: This pan requires 2 extra quarts of fluid: http://shop.advanceautoparts.com/web...131#fragment-2
Old Oct 22, 2012 | 05:42 PM
Gkolo1's Avatar
Gkolo1 is on a distinguished road
Update
I was able to take a #0 Craftsman phillips screwdriver and push it all the way up in that dimple to the handle of the screwdriver with no resistance.
So the top of the dimple is open.
That almost has to be the source of the fluid, But would it just let go for no reason ??
Old Oct 22, 2012 | 05:44 PM
Nope, rust is the reason.
Old Oct 22, 2012 | 05:47 PM
Gkolo1's Avatar
So it would rust even thou it is submerged in oil ??
Just trying to understand why it did it.
In your best guess is that the leak ? I dont know, I put out fires for a living...lol
Old Oct 22, 2012 | 06:53 PM
It's only submerged in oil on one side Just like the differential covers, they rust from the outside in. Only with that, when it pukes, the differential pukes along with it, and you don't know it until it's too late. Unlike the trans, stop as soon as the fluid runs out. If you stuck a screwdriver through the pan, my best guess would be that's where it's leaking
Old Oct 22, 2012 | 07:22 PM
Gkolo1's Avatar
A mechanic just told me to use brake cleaner to remove the oil, use sandpaper to scuff the surface then pack the dimple with JB weld to stop the leak.
Old Oct 22, 2012 | 07:34 PM
All you have to lose is 8 or 10 quarts of trans fluid and a wrecker call, plus a new pan. Personally, I wouldn't trust it. Fix it right: in the long run you've got less money into it, plus the peace of mind of not getting stranded, and it's fixed right.
Old Oct 22, 2012 | 07:42 PM
Gkolo1's Avatar
A former Detroiter says Thank You !
Old Oct 22, 2012 | 08:17 PM
Sure wish I was a former Detroiter Although, being here when the Tigers are in the World Series isn't all bad
