97 Blazer wont start
Here is where I stand on this.My son said he ran out of gas.Added gas and couldnt get fuel past the filter.Will run if you puor gas into throttle body.Changed filter.Getting fuel to Throttle body.Still wont start with out pour in gas.Only runs until gas is used up.
How do you check the fuel pressure.
I would say that the fuel pump is toast. When you replace it go with AC/Delco, the money will be well spent. Also, don't let the tank get below about 1/4 full so the new pump does not overheat and fail early. The fuel surrounding and going through the pump keeps it cool.
I would agree that it definitely sounds like a bad pump. Run through the fuel system diagnostic thread located in the Tech Article (DIY) section as it will give you some additional checks to perform to narrow it down.
The 96 through mid-02 motors were called SCFI (sequential central fuel injection) which had 6 individual electronic injectors in a common injector housing. Each injector then had a flexible line which delivered fuel from the electronic injector to a pressure actuated poppet nozzle which was located in the intake runner. So these were no TBI fuel systems, but rather sequential multi-port fuel injection systems.
The 93-95 CPI motors were batch fired multi-port injection systems.
