97 Jimmy first shift not right
Old Mar 26, 2007 | 10:44 PM
swdockter's Avatar
swdockter is an unknown quantity at this point
Default 97 Jimmy first shift not right
97 GMC Jimmy 4x4 with 146K on the odo. I'll try and explain my problem...
It is only during the first shift from a dead stop. It will turn almost 3K rpm and then drop the rpms to about 2600 rpms and then again to about 2400 rpms and then engage. All subsequent shifts are complexly normal. I have had the trans flushed but the filter was not replaced.
When I cleaned my MAF sensor one day, the thing acted weird somewhat like above but then I found the problem...MAF connector was left off...problem went away but now it's acting somewhat the same. Could it be the MAF sensor? Vacume leak? Or am I going in the wrong direction. I know these electronic trans can act up if sensors are not working.
Any help would be greatly appreciated.
Scott
Old Mar 27, 2007 | 09:40 AM
swdockter's Avatar
Default RE: 97 Jimmy first shift not right
by the way, fluid level is perfect.
gvsu141
Feb 10, 2014 08:15 PM
d44vid
Jan 13, 2012 10:41 AM
kikkegek
Tires and Wheels
20
Oct 12, 2009 08:04 AM
metalhead
Jun 29, 2009 07:16 PM
redpeppers
Apr 7, 2007 04:55 AM
