97 jimmy running extremely rich
Old Feb 16, 2016 | 09:40 PM
  #51
Hole bigger???? Need to grind off the "ears" on the OE hold down bracket, or use an old style SBC hold down bracket.
The Crankshaft position sensor relearn on the Solus Pro is in "functional tests".
Camshaft retard you already found in "engine data". There is no "relearn", unless you consider adjusting, (rotating) the distributor a relearn
Old Feb 16, 2016 | 09:47 PM
  #52
bam_9_9_9's Avatar
bam_9_9_9 is on a distinguished road
nah I was talking about the crank relearn.
what are you talking about grinding off the "ears" ?
I thought in order to adjust the dizzy that you need to make the hole in the hold down bracket bigger to be able to twist it back and forth to get it at 0 degrees.
ohhh I know what you mean now. but it would work both ways right?
Old Feb 16, 2016 | 09:57 PM
  #53
The OE hold down bracket fits around two "flats" on the distributor housing, that's what keeps it from turning. The I.D. of the hole in the intake manifold, is larger than the O.D. of the distributor housing, that's what allows it to turn on an arc. You can remove the OE bracket and grind the "ears" off so the bracket will lay on the round part of the distributor housing, right at the base, and be able to rotate giving you full adjustment to camshaft retard. Once you pull the old one out, you'll see what I'm talking about. Before you pull it out, manually rotate the crank with a socket & ratchet so the rotor lines up with the "6". DON'T rotate the crank, or activate the starter while the distributor is removed. When installing the new distributor, make sure the rotor points at the "6" when it's fully seated against the intake manifold.
Old Feb 17, 2016 | 04:12 PM
  #54
bam_9_9_9's Avatar
ok thanks a bunch man. will post back in about a week. I ordered a new aluminum distributor.
Old Feb 28, 2016 | 04:43 PM
  #55
bam_9_9_9's Avatar
Alright . got the new dizzy in and now i cant even get it running to adjust the cmp. Just spits and sputters. Pops once or twice every few rotations. And sometimes backfires loud through the exhaust. So i thought i had it one tooth off. I checked timming and its spot on. Tdc and rotor points to the 6 exactly. Swapped cap and rotor with the new ones i bought. Same thing. Checked spark again and it jumps a half inch gap. It was running like crap a few weeks ago and now its just pops a few times. Exhaust smells like gas after trying to start it
Old Feb 28, 2016 | 09:13 PM
  #56
Sounds like it's off more than a tooth! Did you follow the suggestion in post #53?
"Before you pull it out, manually rotate the crank with a socket & ratchet so the rotor lines up with the "6". DON'T rotate the crank, or activate the starter while the distributor is removed. When installing the new distributor, make sure the rotor points at the "6"when it's fully seated against the intake manifold."
This is assuming that it's correct to begin with
The distributor and camshaft rotate at the same speed. They make one revolution for every two crankshaft revolutions. #1 piston is at TDC every rotation of the crankshaft. The first time it's on the compression stroke, the next time it's on the exhaust stroke. If you install the distributor at TDC of the exhaust stroke, the engine will pop, fart, sneeze, burp, and backfire when you try to start it The distributor is firing the spark plug at TDC of the exhaust stroke, and it ain’t gonna run
Figuring out which stroke #1 cylinder is on, requires removing the spark plug, disabling the ignition, and the fuel pump, and then crank the starter. While it's cranking, you will hear air "pushing" out of the spark plug hole. On the exhaust stroke, the exhaust valve is open so the "push" is noticeably weaker. On the compression stroke, both valves are closed, causing a much stronger "push", that's the one you need. You need to stop cranking the starter just before the stronger push starts. Then manually rotate the crankshaft clockwise with a socket & ratchet so the dampener marks are aligned like this:
The rotor segment should be pointing at the "6". If not, pull the distributor out, rotate the shaft 180 degrees, and reinstall it so it does.
Attached Thumbnails 97 jimmy running extremely rich-43lvortecfinding1tdc-copy.jpg
Old Feb 29, 2016 | 08:04 AM
  #57
bam_9_9_9's Avatar
Yea thats what i did. It points right at the 6. I will check it again when it gets a bit warmer out. Thanks
Old Feb 29, 2016 | 04:21 PM
  #58
Follow each plug wire and make
sure the cap is wired correctly:
Old Feb 29, 2016 | 06:05 PM
  #59
bam_9_9_9's Avatar
Yea i have also checked that several times hoping to find a crossed wire. But its all hooked up right. I was thinking about checking compression?
Old Mar 11, 2016 | 07:09 PM
  #60
bam_9_9_9's Avatar
Can a clogged cat converter burn up the valves and cause low compression?
I was told the engine missed a bit here and there but nothing major. so that may have been how the cat plugged up. also sort of makes sense when number 6 poppet nozzle was melted at the tip.
going to check compression in a few days. anybody know what the cylinders should be at?
