97 klunking at random when 4WD engaged
Old Aug 15, 2010 | 08:19 PM
Blueline's Avatar
Blueline is an unknown quantity at this point
Default 97 klunking at random when 4WD engaged
Hi - I have a 97 blazer - all lights operate properly on 3 button 4wd switch. Originally found a bad vacuum actuator with broken diaphram. Replaced it and observed both front wheels turning while vehicle on jack stands. After test driving noticed that when in 4hi or 4lo vehicle will produce a loud klunk once in a while - not consistent with any particular speed or rpm.
The sound is sort of like having a bad u-joint. When driving in 2hi the vehicle operates normally, there are no klunking sounds when shifting while parked or while driving.
The problem is only present in 4w drive - just wondering if anyone has experience the same problem.
I've heard of a fork mechanism in the transfer case wearing - just wondering if this would produce the symptoms I've described and how hard it is to repair it.
Old Aug 21, 2010 | 02:59 PM
Blueline's Avatar
4wd repaired - klunking in 4wd mode eliminated - no assistance required.
Old Aug 22, 2010 | 06:09 PM
Glad you got it figured out and sorry that no one responded to you, but could you post what you found that caused your problem? Could help someone else in the future.
Old Aug 27, 2010 | 02:21 PM
Sulley's Avatar
Sulley is on a distinguished road
I am having the same problem with a 98, could you tell me what you did to fix it. Thanks Sulley
Old Nov 3, 2012 | 02:16 PM
blzR's Avatar
blzR is an unknown quantity at this point
STOP doing this people!!
When you find& fix your posted problem(s)>> post your solutions<<!!
I say this with annoyance because i have THIS very exact issue..now i have to keep 'searching"..
Old Nov 6, 2012 | 12:21 PM
mmmrodge's Avatar
mmmrodge is on a distinguished road
I am having this same issue as well. Any help much appreciated!!
Old Nov 7, 2012 | 08:21 AM
Sulley's Avatar
I replaced the transfer case, it was a bad chain. Sulley
Old Nov 8, 2012 | 06:57 AM
mmmrodge's Avatar
that isnt the news i wanted to hear lol. glad you got yours fixed.
edit - mine is the same issue. chain is skipping teeth inside the TC. being replaced today
Old Nov 12, 2012 | 06:43 AM
mmmrodge's Avatar
TC was replaced on Friday. Noise is gone, 4X4 works great! off to the trails and bring on the snow!!
1CrazyJoe
Mar 4, 2012 06:38 PM
1CrazyJoe
Mar 3, 2012 12:42 PM
seamaster2535
Dec 31, 2011 04:54 PM
nhvff57
Mar 11, 2008 11:57 PM
napalm dan
Jan 13, 2007 08:55 PM
