97, S10 blazer 4x4 missfires on acceleration only
Old Jun 2, 2009 | 02:49 PM
SevereDevil's Avatar
SevereDevil is on a distinguished road
Default 97, S10 blazer 4x4 missfires on acceleration only
rerplaced plugs, wire, cap, router, distributor, spider fuel ingector, distrubutor module, air filter, 58-61psi gas pressure, checked vacuum lines as well as possible, replaced gas pressure regulator, still shakes on take off, on idle and cruise is fine. could it be broken cat converter? (seperated pipe) vacuum leak? or timing advance?
Old Jun 2, 2009 | 02:51 PM
What was your reasoning for replacing all of those components?
Fuel pressure looks good.
Have you tried the almost free things like cleaning your MAF sensor, your EGR valve, and your throttle body (including removing and cleaning the IAC valve)?
Old Jun 2, 2009 | 03:21 PM
i just bought it, had to replace most, the vehicle runs better its just this last problem, should i replace it or just clean it? if so how should i clean the maf?
Old Jun 2, 2009 | 03:30 PM
mech cb's Avatar
mech cb is on a distinguished road
Timing?
goldnugget
Jan 26, 2015 03:27 PM
tdbone1
Dec 20, 2012 09:40 AM
Jonas
Jan 15, 2011 04:06 AM
dustinsroberts
Oct 15, 2009 12:08 AM
craighaz
May 14, 2009 06:59 PM
