98 blaser LS in saudi arabia
Old Mar 25, 2009 | 01:45 PM
100C (212F) is getting a bit high, but not really too much of a concern. If it gets up around 110C (230F), you will likely be overheating, but 100C (212F) is not all that bad.
You can make sure that the radiator is clean of all dirt and debris by back flushing it with water from the engine side towards the front of the vehicle. Any debris that is in the radiator itself reduces airflow through the core, resulting in less cooling.
Old Mar 25, 2009 | 04:24 PM
blazer98saudiarabia's Avatar
blazer98saudiarabia is on a distinguished road
The radiator seems clean , but Ill do that on weekend, back flushing....
Old Mar 25, 2009 | 05:16 PM
Just spray through the radiator core itself. Do not do anything with the inside (under the radiator cap).
Old Apr 18, 2009 | 02:52 AM
Thanks...
Have other question, here in middle east have two type of petrol 91 and 95 currently Im using 91...since I bought the car..
somebody told I should be using 95 instead of 91....can I mix these 91 to use 95? or which which is better to use for the blazer for better performance and will not get any problem in the future???
Old Apr 18, 2009 | 03:26 AM
kiwiblazer's Avatar
Originally Posted by blazer98saudiarabia
Swarlkk,
Forget to tell my blazer is import from Japan....Mileage is 90KM when i got it....wheather there is cold.. is there anything I should modify like exust not sure before the muffler or rediator????
WOW! Another Jap Blazer. Is it Left or Right hand drive?
Old Apr 18, 2009 | 04:30 AM
Left hand drive...
Old Apr 18, 2009 | 06:09 PM
kiwiblazer's Avatar
Must've confused the **** outa them!
Old Jul 4, 2009 | 11:21 AM
Modulators,
Need help having problem the air outside is going inside the car, any tips where to check or to closed the vent???? specially when when traffic car infront of me i can smell the smoke coming out from is car.....I tried to put the AC control to HI, Mid, Low...same thing....always Im using the AC currently the temperature here is 49C...very hot
Old Jul 4, 2009 | 03:07 PM
bandidolenny's Avatar
Run the a/c on max which recirculates the inside air... or at least it should if the blend door is working correctly.
Old Jul 4, 2009 | 04:00 PM
I did run the AC on MAx but same the air ouside still coming inside... do you have photo were can I locate the blend door maybe I can closed it permanently...
