98 blazer idling/runnin trouble
Old May 22, 2009 | 02:58 PM
JR Blazer's Avatar
JR Blazer is on a distinguished road
Exclamation 98 blazer idling/runnin trouble
98 lt blazer with about 148000miles on it. idles very rough and stays close to 500rpm at idle and the oil pressure gauge is around 20 until you hit the gas then it goes up to 40. had the distrubutor replaced about 4 months ago. spark plugs are fine. got new tires and there is a squeak coming from the drivesahft which needs to be re greased. stock tires were a 235 70r15 and new ones are 235 75r15. could that cause any problems??? any help is greatly appreciated. thanks
-joe
Old May 22, 2009 | 03:13 PM
I would go through the typical cleaning tasks of MAF, EGR, and throttle body. I bet your idle quality is affected by one or more of those things being dirty.
Larger tires would not affect engine operation. It would affect your shift points in your trans though. Not in a negative/harmful way though.
Old May 22, 2009 | 03:25 PM
JR Blazer's Avatar
i will try cleaning those but the issue is the oil pressure goes down off gas and up on gas. and the same thing happened to my grandpa on his jimmy. the oil pump went and now he has to put a new engine into it.
Old May 22, 2009 | 03:34 PM
Oil pressure is a function of engine RPM. If it were dropping below 10psi, then you may have a valid concern, but 20psi is nothing to be worried about.
Old May 25, 2009 | 07:15 PM
JR Blazer's Avatar
ok. so i replaced the fuse for the gauges and it was back to normal and its still dropping to 20 but no lower. the transmission shifted hard added fluid and it was fine. got a code for the maf vaf sensor and cleared it still idles rough. what next??
Old May 25, 2009 | 07:38 PM
Your oil pressure is fine. Nothing to worry about.
Clearing a code really does nothing. You have to address the cause of the code. Have you cleaned the TB, MAF, and EGR valve as suggested earlier?
Old May 27, 2009 | 03:09 PM
JR Blazer's Avatar
No not doing that is a weather permitting thing. too much rain. Um also i added valvoline water remover to the gas and the idling and take off is much smoother. How exactly do you clean the maf??
Old May 27, 2009 | 03:29 PM
MAF Sensor Cleaning
Check out the thread below for a summary of other informative articles found in the Tech Article (DIY) section:
Tech Article Summary - Check Here first!
Old May 27, 2009 | 04:37 PM
JR Blazer's Avatar
Thank you very much. Im only 16 and any help is much appreciated. Thanks again.
K5BeAst87
Nov 5, 2010 11:51 AM
countryguy1713
Feb 29, 2008 07:50 PM
91s10blazer
Dec 3, 2007 10:04 AM
thejoshx420
Jun 1, 2007 12:08 PM
FieroBob
Jun 12, 2005 10:52 PM
