'98 blazer sometimes rolls forward while in reverse
I have a '98 blazer and occasionally when I first start up my car and switch the car into reverse, the car willroll forward slowlyinstead. It will continue to do this until I restart my car and then it is fine. Reverse is the only gear my car has problem switching into. I'm just curious if anyone else has experienced this problem because it doesn't occur frequently enough for the mechanics to be able to help me out. Any advice would be greatly appreciated. Thanks.
Sounds like you need a tranny filter and maybe a flush...also have the computer scanned for codes to see if there might be some other thing to look into. It might be possible that an internal solenoid for shifting is not working properly and the code would show up in a computer scan...
my blazer does the same thing and i acutally just posed again about my problem tonight. mine is so bad that sometimes im not used to it and i pull forward to back into a spot and i roll out and come close to hitting something.
I did a filter and fluid change and my problem is still there. not saying it wont help yours but im still puzzled on mine [&:]
novaman66
03-21-2011 08:19 PM
