98 gmc jimmy battery light on when key is out
Old Feb 15, 2010 | 02:38 PM
jzalabowski's Avatar
jzalabowski is on a distinguished road
So I literally just got done replacing the ignition switch and ignition lock cylinder in my truck. I took the truck around the block to make sure the lights are no longer on, which they arent, thank god. But now when i remove the keys from the ignition, the battery light goes on, the only thing that is still showing in the truck is my mileage. I think it may be because to remove the keys i have to turn the lock cylinder all the way back, instead of 1 click from all the way back. Is this bad? Is there a way to fix this and get the light off?
I also just took the battery cable off and could see sparks, and it made that sound when you first turn the key when i would make the cable meets the battery. I'm thinking somehow along the lines the truck is still definitely getting power.. i just can't figure out how or where. The battery cable is disconnected just to be safe for now.
Last edited by swartlkk; Feb 15, 2010 at 03:29 PM. Reason: *Combining Consecutive Posts* - Please use the EDIT feature to include additional information in your post if another member has not replied.
Old Feb 15, 2010 | 03:45 PM
Sounds like you didn't get the switch in the proper orientation. You are likely one tooth off and the position to remove the key is actually the accessory position in the switch.
Old Feb 15, 2010 | 10:11 PM
Thanks man. Im amazed how even though things are done incorrectly, this thing will not stop running. Chevys really are bulletproof.
dhud64
Jan 11, 2015 05:27 PM
Blazeme
Jan 14, 2014 08:46 PM
londonmazda
Oct 19, 2010 02:15 AM
damageinc98
Jul 12, 2010 10:47 PM
Charleen53
Nov 3, 2009 02:06 PM
