98' Good fuel pressure, only runs with fuel to throttle body
Old Jan 17, 2018 | 12:08 PM
RobertRannebarger's Avatar
RobertRannebarger is on a distinguished road
Default 98' Good fuel pressure, only runs with fuel to throttle body
I have replaced Fuel Pump, distributor cap and rotor, on my 98' fuel pressure tests 63 psi. It will start if I spray starting fluid in throttle body but will quit as soon as that runs out.
Could this be an issue with the Security system?
Robert
Old Jan 18, 2018 | 10:19 PM
I've never heard of that. I wonder if there is an issue with your injectors?
Old Jan 19, 2018 | 06:14 PM
Mike.308's Avatar
The fuel system is not a fuel pump only. Fuel pump provides the coarse fuel pressure that gets from a:
tank->pump->filter->inlet-socket on plenum->fuel pressure regulator+injectors (aka spider)->fuel outlet socket on plenum->back to tank
The bold place is where You most probably do th test, but the fine fuel adjustment and injection to a combustion chambers is done in an underscored place.
Of course, that could be security (surveillance) system that shuts down the fuel injection, but more likely I'd point the spider.
Any background story ow how it happened?
Brgds, Mike
toolshed59
22
Jan 15, 2014 06:58 PM
jkyleminter
Jul 26, 2013 12:50 PM
ned4spd8874
38
May 30, 2012 05:03 PM
thriller59
17
Jan 25, 2009 04:14 AM
