98 Jimmy BRAKE ISSUE
Old Oct 6, 2010 | 01:51 PM
xowiickedox's Avatar
xowiickedox is on a distinguished road
Default 98 Jimmy BRAKE ISSUE
Ok, So i have a 1998 GMC JIMMY 4 DOOR and the car has had the best maintenance to my knowledge, th vehicle used to stop on the dime when the brake was applied. now the pedal seems to go to the floor , the interesting issue is THAT MY MOM TOLD ME WHENSHE PRESS THE PEDAL TO BRAKE SHE HEARS AIR (I WAS LIKE HUH LOL) I DROVE THE VEHICLE AND PRESSED THE PEDAL AND IT HAPPENS ONLY WHEN B PEDDLE IS PRESSED
( VEHICLE IS SOMETIMES ROUGH AT IDLE THEN PLACED IN N)
Old Oct 7, 2010 | 12:55 PM
Bump SOMEONE PLEASE Write sometHING LOL TO MANY VIEWS NOT TO HAVE ON REPLY
Old Oct 7, 2010 | 01:00 PM
Here's a hint... Turn off CAPS lock! No one wants to be yelled at.
If you hear air, your booster is leaking and in need of replacement.
If the pedal goes all the way to the floor, you either have a leaking line or too low of a fluid level in the master cylinder, both of which would allow air into the lines. You could try bleeding the brakes. This condition could also be caused by a bad master cylinder.
Use some of the key words above in the search function putting a '+' between them to find related threads.
zach bjorge
Mar 17, 2011 06:49 PM
SCBlazer96
Apr 16, 2010 08:39 PM
xderkax
Jan 14, 2010 11:38 PM
Hoelgi
17
Oct 20, 2007 08:49 PM
dashyman
Jan 12, 2007 11:28 AM
