98 timing cover leaking
Had my motor overhauled, oil slowly seeping out of timing cover took back to shop they have replaced it twice and still cant stop the slow leak, They have been using after market parts now they are going to install GM parts, hoping that will fix the leaking , any body have similar problem, the shop has a good rep and have been rebuilding motors for years clean very its freaking them out too. they said they have to pull trans back to install new parts correctly
might not be the cover but a valve cover gasket or the oil cooler lines those are very common for leaking
Has new GM oil cooler hoses, Ill give the shop a call to have them double check the valve cover gaskets ,
oem parts, timing cover
is their a visible difference between an aftermarket timing chain cover and a oem part ? Is the oem cover thicker and is the gasket better ?
| All times are GMT -5. The time now is 01:35 AM. |
