98 timing cover leaking
Old May 28, 2013 | 08:29 PM
TAZ454's Avatar
TAZ454 is an unknown quantity at this point
Default 98 timing cover leaking
Had my motor overhauled, oil slowly seeping out of timing cover took back to shop they have replaced it twice and still cant stop the slow leak, They have been using after market parts now they are going to install GM parts, hoping that will fix the leaking , any body have similar problem, the shop has a good rep and have been rebuilding motors for years clean very its freaking them out too. they said they have to pull trans back to install new parts correctly
Old May 28, 2013 | 09:10 PM
scottl1346's Avatar
scottl1346 is on a distinguished road
might not be the cover but a valve cover gasket or the oil cooler lines those are very common for leaking
Old May 28, 2013 | 09:44 PM
TAZ454's Avatar
Has new GM oil cooler hoses, Ill give the shop a call to have them double check the valve cover gaskets ,
Old Jun 1, 2013 | 06:57 PM
TAZ454's Avatar
Default oem parts, timing cover
is their a visible difference between an aftermarket timing chain cover and a oem part ? Is the oem cover thicker and is the gasket better ?
user3657
Nov 22, 2009 04:46 AM
black95blazer
Jan 30, 2008 05:01 PM
kgould67
Oct 16, 2007 12:49 PM
frankjc
Aug 7, 2006 11:12 AM
