99 4.3 help
Old Jul 27, 2010 | 12:27 AM
The_Fabricator's Avatar
The_Fabricator is on a distinguished road
Default 99 4.3 help
it was running fine and then it started to have a miss and when you snap the throttle it will some times die and other times it will stumble along. But if you bring the rpm up slowly it doesn't miss a beat. It also is hard to start any help would be great
here is a list of what has been replaced in the last year or so, spider injection (twice because the first one blew the pressure reg out) distributor, cap, rotor, wires, plugs, maf, coolint temp sen, timing chain, o2's, upper intake (was flexing causing a vacuum leak) iac, egr cps, (because i broke it oops)
Thanks mike
Old Jul 30, 2010 | 02:17 AM
any help would be good im at a loss here so far
Old Jul 30, 2010 | 06:35 AM
Peru Motors's Avatar
Peru Motors is an unknown quantity at this point
I'd put a fuel pressure gauge on it and see what it says. Key on, running in place and tape it to the windshield and drive it. This should rule out (or not ) a fuel, fuel pump issue. Didn't see where you did this-if it ends up being fuel pump, buy quality like AC Delco. Jerry
Old Jul 31, 2010 | 02:32 PM
Did that ! Fuel pressure is good and all the parts i've put on have been AC Delco. So now Im going to start to dig in to the engine. Im thinking it mite be the cam !!
Old Aug 7, 2010 | 07:39 PM
fixed it
it ended up being the dizzy again grrrrrr all good now
Old Aug 7, 2010 | 07:44 PM
TripleBlackBlazer's Avatar
Thank you for following up with this!
