99 4x4 Vibrates when decelerating
Old Mar 26, 2012 | 09:10 PM
Bwalls's Avatar
Bwalls is on a distinguished road
Default 99 4x4 Vibrates when decelerating
Hey everyone,
I have a 1999 5-speed 2 door 4x4 Blazer. Truck has 245k miles on it, engine has only about 175k.
This morning on my way to school I noticed when I decelerate, from about 35 mph down to 10 mph (1.5 RPM to 0.5 RPM) my truck vibrates a good amount. Dash, steering wheel, and door panels shake. it almost feels like the vibration when you take off into first gear and don't give it enough gas.
This vibration happens when I'm on OR off the brakes, therefore I'm convinced it's not the brakes. It also happens when simply coasting to a stop. When I accelerate at any point during the slowing down process the vibration instantly goes away. The truck does not vibrate when you're on the gas. Also, does not matter if I'm in neutral, or downshifting through the gears.
I'm thinking it's an idle problem... any thoughts?
Old Mar 27, 2012 | 04:20 PM
step66's Avatar
I'd look at the u-joints...
Old Mar 27, 2012 | 04:41 PM
Bwalls's Avatar
I checked it out on a lift today. I turned both front wheels and the back ones turned too. It was stuck in 4 wheel drive, but my in dash switch said 2 Hi. Found out the vacuum switch was holding pressure and keeping the front diff. engaged. Pulled out the line and it released. It was a bad switch, and I just replaced it from GM a month ago. Thanks anyways guys.
Bertbart
May 29, 2012 08:06 PM
LilPudge666
May 19, 2012 05:04 PM
mntnrider
Jan 7, 2011 04:19 PM
yazan84
Dec 30, 2007 11:19 PM
ronnie.d
Apr 12, 2006 06:48 PM
