'99 Blazer ABS light is back.
Old Dec 13, 2013 | 02:02 PM
my2k2zx2's Avatar
my2k2zx2 is on a distinguished road
Temps have been < 40F all week, the ABS light has not come on once.
I guess it's a waiting game until it's warmer out for the light to come on.
Old Jan 8, 2014 | 03:25 PM
my2k2zx2's Avatar
Still having issues with this, about 2-3 times a week. I took it in again and they were able to pull the codes. They didnt write down the code #s, but said it had codes for "LF speed sensor", "Rear speed sensor" and "stop switch short to ground". ABS works when the light is off, but not when the ABS light comes on. If I shut it off and restart, the ABS light usually does not come back until about 5-10 minutes later.
They said those codes were not enough for them to know where to start. They want to see it with the ABS light on.
Old Jan 8, 2014 | 03:39 PM
Read post #10 again. Especially the last paragraph.
Old Jan 8, 2014 | 03:56 PM
my2k2zx2's Avatar
That's the problem, whenever the light comes on is in the evening when everything is closed. I drive by an Autozone on my way home, but the light has never been on when I drive by. Their free scan would be able to check the ABS codes, right?
Old Jan 8, 2014 | 04:07 PM
Only if the scan tool is ABS capable. Typically the auto parts stores scan tools are powertrain only, (no ABS, no BCM, no airbag, no IPC, no HVAC, etc). The ABS DTC's remain in the history file until they are manually cleared or the problem doesn't exist anymore. I can just about gaurantee their scan tools can not access the history files.
Old Jan 8, 2014 | 09:36 PM
canuck blazer's Avatar
canuck blazer is on a distinguished road
I know on my 2002 traced the wires from the front hub found one that had most of it worn through will be replacing it in the spring
Old Jan 13, 2014 | 09:54 AM
my2k2zx2's Avatar
I was driving early this morning and noticed the headlights flicker just a bit before the ABS light comes on. It's coming on now after 3-5 minutes. Going in tomorrow to have it checked out.
Kaffeene
Sep 23, 2012 12:00 AM
Tinted
Mar 15, 2012 02:56 PM
damageinc98
Jul 12, 2010 10:47 PM
stormshadow1
Apr 23, 2009 09:46 AM
95_Blazer
Dec 6, 2007 09:44 AM
