99 Blazer - bumper license plate lamps - fit???
Old Nov 8, 2009 | 05:42 PM
dg98adams's Avatar
dg98adams is on a distinguished road
Default 99 Blazer - bumper license plate lamps - fit???
Both of the license plate lamps had to have both bulbs recently. Now I can not figure out how to get the white lamp lens back into the bumper??????
I had to by a new lens because I broke the "tang"...HELP
Old Feb 28, 2010 | 01:06 AM
dg98adams's Avatar
bump...any help here?
Old Feb 28, 2010 | 09:36 AM
beefgravy's Avatar
beefgravy is on a distinguished road
The white plastic is not supposed to come out, you are supposed to reach behind the bumper and twist the plug out of that socket then back in. If you took the clear lense cover off the bumper itself by prying it off, you most likey broke the tabs.
You may have to go to the junk yard and get some used ones. The should come out by pusing in the tabs on the back side under the bumper and pushing the plastic out.
Beef
Old Mar 1, 2010 | 06:48 AM
dg98adams's Avatar
I wasn't able to get behind the bumper...but that makes sense. Maybe there is something I can remove to get access? I'll check when the driveway is cleared and it gets a bit warmer.
Thanks
Old Mar 1, 2010 | 10:19 AM
beefgravy's Avatar
No problem. Should be able to reach right under it but I guess it could have a trim piece or something covering it. Good luck
ChromeJerome
Aug 30, 2023 08:49 PM
RandyRhoadsFan82
Feb 22, 2014 09:38 PM
pbd3mon
Dec 29, 2007 08:24 PM
Chevy Lover
Jul 4, 2006 03:52 AM
16gauge
Oct 17, 2005 12:01 AM
