99 Blazer A/C hose and compressor connection
Old Sep 14, 2011 | 02:46 PM
TimAH's Avatar
TimAH is on a distinguished road
Default 99 Blazer A/C hose and compressor connection
Wondering if anyone has a good picture of the connection between the a/c hose and the compressor, particularly on the drivers side. I recently swapped out a compressor and thought this area looked a little strange when I installed the replacement it seemed tight but it appears to sit higher than I was expecting. After filling the refrigerant I can tell its definitely leaking from that area. I am not sure if its a case of a bad washer ( I did replace them) or if i just didn't get the thing to quite sit properly.
Old Sep 14, 2011 | 03:36 PM
Here are a few schematics from CompNine.com: Schematic 1 & Schematic 2
There really isn't any way to screw it up provided you purchased the proper parts...
Old Sep 14, 2011 | 04:01 PM
TimAH's Avatar
thank you. I can see the dye around the area the washer thats labeled 4 on the 2nd schematic. That particular washer was a bit of a pain to get on there so maybe I managed to alter its shape a bit.
Old Sep 14, 2011 | 04:09 PM
If you see dye, you definitely have a leak. The seals should not go on difficult.
Old Sep 14, 2011 | 04:20 PM
TimAH's Avatar
Is it possible that the metal expanded causing the difficulty in putting the seal on or is it more likely the new seal was just a tiny bit too small? Both the old seals came off easily and the other new seal went on with no problems.
Old Sep 14, 2011 | 04:26 PM
It's likely that the seal you installed was not the correct size.
btb1003
Apr 9, 2014 11:08 PM
86TransAm
14
Dec 13, 2011 07:46 PM
ROFLsplash
Nov 27, 2011 02:12 PM
gmcjimmy_94
Dec 30, 2010 12:37 AM
rob1621
Apr 3, 2008 08:55 PM
