99 blazer with issues
Old Jul 18, 2012 | 07:51 AM
jbyrd1977's Avatar
jbyrd1977 is on a distinguished road
Default 99 blazer with issues
my 99 blazer takes a few more seconds than normal to start stalls on turns but fires right back up and you have to feather the gas till it warms up to go anywhere. any help would be great its my wifes blazer I have jeeps lol
Old Jul 18, 2012 | 10:41 AM
50lb_cat's Avatar
When is the last time it had a tune up? And has the MAF sensor ever been cleaned?
Old Jul 18, 2012 | 03:58 PM
jbyrd1977's Avatar
just did plug wires cap and rotor doing plugs tonight
Old Jul 19, 2012 | 10:55 AM
99Legendary's Avatar
99Legendary is on a distinguished road
Did you use all ACDelco brand parts for the tune-up? Blazers are very picky when it comes to tune-ups.
Old Jul 19, 2012 | 01:38 PM
50lb_cat's Avatar
You can try unplugging the MAF sensor to see if it helps. If it does then it needs cleaned. If you don't see a change then I would do a fuel pressure and leakdown test.
Old Jul 19, 2012 | 05:19 PM
Micscience's Avatar
Micscience is on a distinguished road
Is the check engine light on? It wouldn't hurt to go over all your connections dist,plugs,wires,maf,fuel and more and check your spider fuel injectors for anything out of whack. Why it stalls when you turn is a puzzle I'm trying to figure out what is the difference when turning than going straight the only thing I can think of is the power steering and belt how is your serpentine belt?. Did you only wash the engine bay? did you do anything else to the car?
Old Jul 20, 2012 | 03:23 PM
jbyrd1977's Avatar
I dissconected the MAF now its not stalling but I also put a full tank of HI tes in her and ran her down the hi way now it just spits and sputters in the am after that its fine till after work for a min of running
Old Jul 20, 2012 | 03:26 PM
jbyrd1977's Avatar
used bosh tripple platinum plugs and bosh wires
Old Jul 22, 2012 | 11:58 AM
Micscience's Avatar
I would have used OEM AC Delco but clean your MAF sensor with MAF cleaner.
Old Jul 22, 2012 | 12:14 PM
50lb_cat's Avatar
+1, get some CRC MAF sensor cleaner and spray the wires after removing it from the air intake. Do not touch the wires!
