99 blazer rear end problem/axle removal
Hey all,
Am in the process of replacing the backing plates on the rear end of my 99 blazer, I took the diff. cover off and tried to remove the pinion shaft locking bolt, so I can remove the rear axles. but the bolt is starting to get rounded off and wont budge. any help with this problem would be great!
don't use a 12 point boxed end wrench? definitally not the open end
I managed to get a 6 point socket on mine
what size is the bolt?
Getting that stupid little bolt off is usually tied with heavy curse words.
Yes, use a 6 point wrench or socket. I have a special tool for snap-on that is actually for brake line bleeders but works great on that bolt too. You may be able to find a similar tool at a parts store. It looks like this http://buy1.snapon.com/catalog/item....re&dir=catalog
thanks for everyones input.....the bolt is 8mm, and I was able to bust it loose when I bought a 1/4 universal swival and was able to get a socket on it.
I have actually had the head break off of that bolt.GRRRRRRRRRRR ![Icon Doh](https://blazerforum.com/forum/images/smilies/icon_doh.gif)
The shaft that the bolt goes through had very slightly worn into the smooth part of the bolt. This had the bolt in a bind. I have no idea why it did this.
Always tap both ends of the shaft you are removing and watch to see that it just barely moves back & forth to be sure it is not binding on the bolt before trying to remove the bolt.
I broke the bolt off in my IROC. I just replaced the rear end since I had another disc brake rear end in the shed.
If I ever do another one I will use a propane torch to heat the bolt up a little first to soften/loosen the loctite on the threads.
brino1
02-25-2011 08:05 PM
fowellkris
03-07-2010 04:45 PM
