99 blazer starter wont run
Old Sep 7, 2014 | 04:05 PM
cctcct67's Avatar
cctcct67 is on a distinguished road
Default 99 blazer starter wont run
I pulled my winter truck in the garage to do a caliper and couldn't start it after charging the dead battery on it. It was starting fine before just needed a jump because battery is shot. I put new battery in with no luck. Now all the dash lights, gages and radio, head light all work, just wont kick starter I can hear fuel pump prime when key is turned to on and I can hear starter relay pull in when turned to start position but no luck. The key also seems little sticky in off position have to wiggle it a little to turn( this just started last week when I started it). Not sure where to go with it ignition switch or neutral safety switch any trouble shooting help would be appreciated. Thanks in advance
Old Sep 7, 2014 | 05:19 PM
newguy's Avatar
starter could be frozen up or dirty connections on starter. Try tapping the starter a few times with a hammer
Old Sep 7, 2014 | 06:50 PM
cctcct67's Avatar
I tapped with a hammer too but no luck. I also tested voltage at crank fuse i have 12 volt while ignition is in crank position.
Old Sep 7, 2014 | 08:05 PM
rexazz2's Avatar
fuseable link at the starter ??
Old Sep 7, 2014 | 08:24 PM
jmparker82's Avatar
jmparker82 is on a distinguished road
depending on how cold it is up there right know...If water got in the starter and froze that could be a problem. Had it happen before and i just chose to replace the starter. Otherwise i would check all connections.
Old Sep 7, 2014 | 09:22 PM
cctcct67's Avatar
Not even close to freezing here yet. I'm going to pull the starter tomorrow and bench test it and test wiring also.It may just be bad connection its a rusty winter beater that hasn't even been washed in like 3 years. lol
Old Sep 7, 2014 | 09:23 PM
cctcct67's Avatar
is there a fuseable link at starter? if so where?
Old Sep 8, 2014 | 06:09 PM
jmparker82's Avatar
I don't know.
Old Sep 9, 2014 | 11:11 AM
cctcct67's Avatar
Well got the starter out to find the wire that goes to motor had corroded and broke off. Put a starter in from the yard now its all good thanks any how guys.
Old Sep 9, 2014 | 05:02 PM
jmparker82's Avatar
Anytime we can try to help we are here.
m3dragon
Feb 24, 2015 10:04 AM
jdmmario
Oct 25, 2014 06:25 PM
dj00140
May 20, 2013 06:37 PM
jbobon007
14
Jul 1, 2011 05:30 PM
CHEVETTE LOVER
Mar 15, 2010 10:39 PM
