99 Blazer Upper Control Arm
Old Dec 7, 2012 | 10:02 PM
ExpressEN1's Avatar
ExpressEN1 is on a distinguished road
Default 99 Blazer Upper Control Arm
I just purchased an upper control arm / ball joint assembly from O'Rielley Auto Parts. It is the "MotorPro" brand to keep the nut from coming off. I am just a bit concerned because the ball joint does not use a castle nut and cotter pin. It uses a flat washer and some sort of serrated nut. Has anyone else used these and how safe are they.
Old Dec 8, 2012 | 07:04 AM
05BlackJimmy's Avatar
05BlackJimmy is on a distinguished road
does the nut have a nylon ring in it?
Old Dec 8, 2012 | 08:17 AM
ExpressEN1's Avatar
No, it's not any kind of lock nut that i'm familiar with.The nut looks something like this.
Old Dec 8, 2012 | 12:31 PM
Can't really see the picture but if it looks like this
Google Image Result for http://image.made-in-china.com/43f34j00IsStTzJCYEcp/Serrated-Flange-Lock-Nut.jpg
Its a locking nut.
Old Dec 8, 2012 | 04:20 PM
ExpressEN1's Avatar
That's what it looks like. I just hope it holds because it came with a flat washer.
Old Dec 8, 2012 | 04:50 PM
Does it fit without the washer? I'd probably use it without the washer if it does.
Old Dec 13, 2012 | 07:15 PM
ExpressEN1's Avatar
Smile
Thanks for your reply. I'm going to ditch the flat washer so the nut tightens directly against the hub.
Thanks
Old Dec 13, 2012 | 07:27 PM
Blazin00LT's Avatar
Blazin00LT is on a distinguished road
Drill a small hole in the stud and insert your own cotter pin.
Old Dec 14, 2012 | 07:16 PM
ExpressEN1's Avatar
Been thinking about doing just that.
Old Dec 14, 2012 | 08:41 PM
coolasice's Avatar
coolasice will become famous soon enough
you could get a matching locknut to run up under the first nut and lock it in place...
