99 Bravada missing, P0303
Old 03-27-2015, 03:41 PM
Good job. If the misfire persists, there are several other things we can check into. Also, your 1999 is a candidate for a GM TSB involving a binding condition with the valve guides under heavy load acceleration.
Old 03-27-2015, 04:23 PM
No false Bravada's Avatar
No false Bravada is on a distinguished road
Thanks. If it were a part of the TSB, wouldn't it likely read a P0300/P03xx for multiple misfires under heavy load?
I just took it down a muddy dirt road, and while I could feel it miss at WOT, and it did set a P0303 with SES light on, I looked and the wire was rubbing up against the exhaust manifold. Good thing the wires are on the way.
I guess when it cools down, I can wrap it with electrical tape and use a zip tie to keep it out of the way for now. Had a similar issue on my 93 Cheyenne, which had the TBI 4.3. The wires ought to fix it.
Old 03-27-2015, 04:27 PM
Binding valve guides will usually cause the check engine light to flash and set a DTC in memory.
Sounds like you need new wires too
Old 03-27-2015, 04:55 PM
It was probably arcing on the #3 wire. I've got it taped and out of the way, I'll go hit the dirt road and see how it does.
Still going to run MMO through the PCV line to help clean the valves. Did wonders for the Alero. Different vehicle and engine, yes, but same idea. That cool MMO hitting the hot valves ought to help break up the carbon build up. I probably shouldn't do it at home. I did it with the Alero near home, and it put up one hell of a smoke screen.
Old 03-28-2015, 02:03 PM
Just for laughs, I went to Autozone and got a 24" wire and modified it to fit. No miss at idle or WOT now, nor has it set off the SES light or any codes my scanner could see. Pulls steady and smooth. Can't wait for the proper wires so I can be finished.
Blade_24k
11-23-2021 01:36 PM
palmer96
07-29-2013 11:46 PM
97cherryblazer
05-19-2012 04:15 PM
96realwe
12-10-2010 09:19 AM
swarfel
06-16-2009 08:29 PM
Quick Reply: 99 Bravada missing, P0303
