99 Jimmy Injection Spider testing/repalcement
Old Jan 11, 2011 | 11:09 AM
DrSinisterr69's Avatar
DrSinisterr69 is on a distinguished road
Default 99 Jimmy Injection Spider testing/repalcement
I have a 99 Jimmy driving along, just quit. Fuel pump running, good spark. Looking for information on testing and replacing the injector assembly. I just want to make sure I'm not replacing the assembly, if it's not needed.
Thanks,
Old Jan 11, 2011 | 11:52 AM
rriddle3's Avatar
Originally Posted by DrSinisterr69
...Fuel pump running...
Okay, but do you know what the pressure actually is? Follow all the steps in 96+ Fuel System Diagnosis.
Old Jan 11, 2011 | 12:07 PM
Default Fuel Pressure
The fuel pump is running, and was just replaced not too long ago. I did not check the pressure, figuring it should be ok since the pump is pretty new.
Old Jan 11, 2011 | 07:06 PM
Don't assume that the pump is good just because it was recently replaced. Aftermarket pumps are junk.
Old Jan 13, 2011 | 11:38 AM
Thank you. You were correct, I checked the pressure at the test port, 40psi, almost went to 50psi, thats it. I am going to replace the fuel filter first, but I think your right on the pump.
Old Jan 13, 2011 | 12:04 PM
Does the pressure hold steady once the pump shuts off?
coasterkid
Jan 27, 2010 12:42 PM
SlydinClyde
Oct 20, 2009 12:56 AM
97lsblaza
Jun 12, 2009 09:19 PM
banshee386
Apr 20, 2009 10:00 AM
GeorgeLG
Jan 22, 2007 07:05 PM
