99 Jimmy Wont start
Old Jan 19, 2016 | 05:02 PM
  #41
litlmeal's Avatar
litlmeal is on a distinguished road
Originally Posted by Captain Hook
Drops to 40psi while cranking the starter? How long were you cranking?
Yes while cranking. Cranked for about 5 seconds each time
Old Jan 19, 2016 | 05:16 PM
  #42
The poppets will not open if/when fuel pressure drops below ~40psi. The drop that you saw, is exactly right. The injectors are in fact squirting fuel, at least one of them is anyway
When everything is connected, are you still getting the backfire when try to start the engine?
Old Jan 19, 2016 | 05:24 PM
  #43
litlmeal's Avatar
No it cranks over good and sputters a few times but never starts. No backfire thru intake anymore.
Old Jan 19, 2016 | 05:30 PM
  #44
The air intake tube is connected to the throttle body, and to the MAF sensor, correct? If so, add a one second shot of carb cleaner in the air inlet and try to start it.
Old Jan 19, 2016 | 05:47 PM
  #45
litlmeal's Avatar
Yes both are connected to throttle body. Sprayed carb cleaner in and it stuttered a little more. Every once in a while i hear i knock noise now that it is firing a little. It kind of sounds like a starter skipping tooth to me
Old Jan 19, 2016 | 05:52 PM
  #46
In your first post, you mentioned spark looked good using an inline spark tester: What size gap did you have it set at? Was the spark blue?
Old Jan 19, 2016 | 06:01 PM
  #47
litlmeal's Avatar
Gap was at .060. The inline tester i have only lights up red like a test light when spark hits it,its from mac . mac # st400
Old Jan 19, 2016 | 06:10 PM
  #48
.060 should be the spark plug gap. I am familiar with the ST400, but I need you to make another test. Pull the coil wire from the distributor and slide the boot back to expose the terminal. Prop the terminal up so there is about a half inch gap to ground, and crank the starter. (don't hold the wire unless you need your hair straightened) There should be a rhythmic blue, not orange, spark.
Old Jan 19, 2016 | 06:30 PM
  #49
litlmeal's Avatar
Did that and spark is orange no blue at all
Old Jan 19, 2016 | 06:33 PM
  #50
Was it rhythmic, not erratic? Do you have jumper cables or a decent size battery charger? Spark needs to be blue, orange is weak, could be low battery from all the cranking lately.
