99' starting problem
Old Mar 2, 2010 | 07:01 PM
nomadd15's Avatar
nomadd15 is on a distinguished road
Default 99' starting problem
I have a 99' LS series. When the engine is cold i can crank it over all day and it won't start. But if I tap the key it will try to start, after tapping the key 5 or 6 times it will start. When the engine is warm it starts right up, warm days are no problem. Fuel pump primes on start up , and I get no engine light or codes
Old Mar 2, 2010 | 07:12 PM
RonJon's Avatar
RonJon is an unknown quantity at this point
Start by checking the fuel pressure. Also if you haven't replaced the filter lately - do so.
Old Mar 2, 2010 | 07:42 PM
nomadd15's Avatar
Fuel pressure is at 52 , also replaced filter.
Old Mar 2, 2010 | 07:56 PM
theclothedcreature's Avatar
theclothedcreature is on a distinguished road
how cold
Old Mar 2, 2010 | 08:31 PM
RonJon's Avatar
GM sez you should have between 60-66. My best friends 2000 had a starting problem and also had 52 psi. New pump solved it. It's "possible" that it's a different problem like a leaky regulator but my guess is go shop prices for a pump. I know it sounds like a lot of pressure but you don't have enough for the enrichment for cold starts and the day will come soon you won't have warm starts either.
cgrett
Nov 15, 2010 09:08 PM
Sprocket
Mar 20, 2008 09:39 PM
mickey2001
Mar 13, 2006 11:51 AM
ghassell
Feb 6, 2006 09:51 PM
blazin97
Jul 9, 2005 03:32 AM
