ABS and Airbag lights won't go off..
Old May 3, 2012 | 09:29 PM
neemo6's Avatar
neemo6 is an unknown quantity at this point
Default ABS and Airbag lights won't go off..
I have a 97 jimmy and for the last few months the airbag light has stayed on and intermittently goes off but eventually comes back on. Here recently now the ABS light has been on and all my interior dash lights are not lit anymore. What could be going wrong and how can I fix it?
Old May 3, 2012 | 11:51 PM
4x4blazerguy's Avatar
First a WARNING airbags are nothing to fool with unless you have experience with them. If they deploy while your messing with something your in for a major repair bill or possible injury.
But what comes to my mind is a loose ground or a relay or fuse that needs to be pulled & replaced. My ABS light keeped coming on & off. I replaced both front sensors & it still acted up so I pulled the fuses & put them back & that seems to of fixed it. The get a little corrosion or something & by pulling them you break that off & make a better contact.
Old May 4, 2012 | 04:27 PM
I.B.Stuck's Avatar
I.B.Stuck is on a distinguished road
Another option may be the key switch harness. My ABS light would come on, the drivers side power window would become non-op and the heater fan would turn off. I replaced the key switch wire harness (not as bad as it sounds) and all the problems went away.
Old May 4, 2012 | 09:36 PM
Thumbs up
Good Point worth a look for sure.
Bolbol
Jan 5, 2021 04:27 AM
kmartin
46
Mar 14, 2018 10:25 AM
builder125
May 20, 2013 06:51 PM
builder125
May 11, 2013 07:20 AM
mccainthepain
Jan 29, 2009 08:18 AM
