Abs and brake light issue
Old Feb 5, 2019 | 06:18 PM
Rowen's Avatar
Rowen is on a distinguished road
Default Abs and brake light issue
Hi, I have a 2000 blazer 2wd and the ABS and braje warning light will come on and then go off, usualy after I turn the vehicke off and then back on. Has anyone tried the Fixd device? Does it read for this problem?
Old Feb 6, 2019 | 06:34 PM
Rock18's Avatar
Rock18 is on a distinguished road
Fixd would probably read the codes to give you an idea of what's going on. There are also cheaper bluetooth OBD adapters like this one that will get the job done, and most auto parts stores will scan the codes for free.
Reading the codes will tell more definitively, but this sounds like a very common problem with solder joints within the ABS control module failing after a while. The good news is that if that's the problem you can send your ABS module off to be rebuilt for around $50.
Old Apr 11, 2019 | 03:48 PM
kmenc67's Avatar
kmenc67 is on a distinguished road
That's almost always an intermittent ground problem. Advance, O'Reilly, etc can check for those abs codes (I think it's C0265). Common problem with the Kelsey/Hayes ABS modules in Blazers. You can try cleaning off the ground contact that connects to the body just behind the driver side headlamps (have to remove the air filter box). If that doesn't do the trick, it would probably need the solder joint fix to the abs module. Mine have been going on and off for over a year and I've just been ignoring it, but will probably send mine off for a re-solder at some point.
Old Apr 12, 2019 | 10:52 AM
puttster's Avatar
That happened to me, too. A good member here resoldered the module for me and everything was cool for a few years but now the lights are back on. Accorfing to Youtube there are six joints that are susceptible to getting shaken loose, so when I get time to practice soldering, I think I will give it a go myself. The screws that hold the module down are a b*tch but I replaced them with normal screws so at least that's not a problem.
Old Apr 13, 2019 | 10:54 AM
Mike.308's Avatar
Originally Posted by Rowen
brake warning light will come on and then go off, usualy after I turn the vehicke off and then back on.
That is, when You turn the key on / engine off the brake indicator lits. With key on / engine on it should go off. If the indicator remains off while You drive, I'd consider it normal.
Otherwise, follow Puttster advice. And You may check the ground wire connector at the radiator support, down below the air filter.
Old Apr 16, 2019 | 02:11 PM
Zenith's Avatar
Zenith is on a distinguished road
Old Jul 3, 2019 | 05:08 PM
AutoXpressTech's Avatar
AutoXpressTech is on a distinguished road
AutoXpressTech rebuilds the Kelsey Hayes 325 for $49.99
We can replace the Kelsey Hayes 310 w valve assembly for $399. PN 12475489
Old Jul 3, 2019 | 05:10 PM
Send the Kelsey Hayes 325 Module to AutoXpressTech
run_girl
Nov 7, 2016 02:32 PM
rxjimmy
46
Sep 5, 2016 01:33 AM
antman94
Apr 16, 2012 07:51 PM
samuknow
Apr 20, 2010 11:09 AM
BIG-RED
Nov 6, 2009 06:52 PM
