ABS Ground Location on a 98 Blazer
Old Apr 27, 2016 | 07:07 PM
Dabman's Avatar
Dabman is on a distinguished road
Default ABS Ground Location on a 98 Blazer
Hey guys,
1st post here!!!
Been having ABS problems, Codes C0226, C0265, and C0227
Replaced the front left bearing today and now I'm only down to 1 code!!!
C0265
I have the Kelsey Hayes 310, and from what I read it is not prone to circuit board corrosion failure as other EBCMs
I believe I may have a ground issue. I used the ModuleMasters "Kelsey Hayes 310 ground diagnostic" sheet (Kelsey-Hayes 310 ABS Module | ModuleMaster) and get the following readings:
Step 1: 0.3 ohms
Step 2: 0.9 ohms
Step 3: 0.5 ohms
My main question is where is the ground located on my frame for the EBCM for my 98 Blazer?
Thanks for the help guys!!!
Old Apr 29, 2016 | 06:14 PM
At the EBCM connector 1, pin J, is a black with white stripe wire. It runs through the underhood fuse panel, then goes to the rear of the right cylinder head, (along with a few other grounds).
Pin B is a black wire and runs to the left radiator support.
Survivor
Mar 13, 2020 04:38 PM
eljorgin
May 21, 2019 10:04 PM
Dug44
Nov 29, 2012 06:24 AM
rdhack
Jun 7, 2009 03:38 PM
cide
May 1, 2009 01:07 PM
