ABS issue, New blazer owner
I have recently purchase a 1998 Blazer LS 4x4. I started noticing that my ABS seems to be engaging as i slow down to make a stop. No light comes on, but the pedal depresses & you can hear the moan of ABS engaging. After reading through posts on here I found that to be a common issue, so i tried the remedy of cleaning the WSS & surrounding area. After doing so it engages much less, but it still does every now and again. Upon cleaning I noticed that on one of the WSS (front drivers side) there was a blue colored grease all over, but yet nothing on the opposite side. So my question is if that's normal, or is it something else causing the issue? A bad bearing/hub maybe? I'm new to all this so it may seem like an obvious answer but I don't have the money to keep bringing into shops to get checked & was hoping to be able to fix it on my own.
Probly bad bearing and or speed sensor wire. I had the same issuse and one of my hubs had rust in it (wasnt bad...yet) but enought rust got on to the sensor and was kicking my abs. i originaly replaced just the sensor witch worked. But later eventualy replaced both my hub assemblys. Both of witch came with new wires.
So i would start with removing the sensors and look at them and in the bearing, if they are dirty you could probly just get away with wipeing them off, but i personaly veiw that to be a short term fix. and if you dont know what wire it is, its the only wire coming off the front hubs, needs an allen wrench to take off.
Chauncy
Jan 26, 2013 10:47 AM
simplyjessi
Jan 21, 2012 10:10 PM
ramairmustang
Feb 24, 2010 01:09 AM
jonmouse
15
Jan 30, 2006 09:43 AM
