ABS Light - 1999 Blazer
Old Feb 27, 2010 | 07:04 PM
gravis346's Avatar
gravis346 is on a distinguished road
Default ABS Light - 1999 Blazer
I just had my right upper/lower balljoints replaced - now the ABS light is on. Anyway to reset? Thanks for any help.
Old Feb 27, 2010 | 07:05 PM
Spectreblazer's Avatar
Banned
Spectreblazer is on a distinguished road
was it on before?, make sure your wheel speed sensors didn't accidentally get pulled out from the hub/bearing. once the problems corrected the light should go out. you shouldn't have to reset it.
Old Feb 27, 2010 | 07:09 PM
gravis346's Avatar
Thanks, it was not on before the work was performed.
Old Feb 27, 2010 | 07:12 PM
Banned
also if you follow that wire from the hub up and under the plastic flap. there is a connector there. i had one come unplugged once and set the light off, you might want to check that out too while your at it.
kamilkowalski
Apr 30, 2015 08:36 PM
Tinted
Mar 15, 2012 02:56 PM
damageinc98
Jul 12, 2010 10:47 PM
stormshadow1
Apr 23, 2009 09:46 AM
95_Blazer
Dec 6, 2007 09:44 AM
