ABS Light
Old Mar 9, 2010 | 03:53 PM
wireman's Avatar
wireman is on a distinguished road
Unhappy ABS Light
ok...had my 2002 blazer for about 2mos now and it runs beautifully.......so why is my abs light blinking on/off? Other than checking the brake fluid,can anyone offer suggesstions?
Old Mar 9, 2010 | 04:05 PM
If the ABS light is coming on, there is likely a recorded fault in the ABS control module. Not every scanner can access this though.
If it is intermittent, it could be a problem with the brake fluid level or the sensor that is in the reservoir. It could also be a problem with a wheel speed sensor wire being pinched or otherwise damaged.
Does the ABS system ever activate under light braking?
Old Mar 9, 2010 | 04:28 PM
TheBrettster's Avatar
TheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond repute
Is the e-brake going on at the same time? If not its most likely a wheel speed sensor, have you changed the ride height on your vehicle at all?
Old Mar 9, 2010 | 08:55 PM
Cerion's Avatar
Cerion is on a distinguished road
My abs light started coming on and off about when my hub bearing assembly started to fail in my front passenger side wheel. After I got that fixed (around $400), the abs started to function normally. If you start to hear anything resembling popcorn popping, that'd probably be it.
Old Mar 13, 2010 | 07:25 AM
wireman's Avatar
I just replaced that one about 1 1/2 mos ago.....and the brake fluid is fine.
Old Mar 13, 2010 | 07:26 AM
wireman's Avatar
The e-brake is not coming on at all...no I have not changed wheel height
Old Mar 13, 2010 | 07:27 AM
wireman's Avatar
I guess I need to see if any wires are pinched
Tinted
Mar 15, 2012 02:56 PM
damageinc98
Jul 12, 2010 10:47 PM
stormshadow1
Apr 23, 2009 09:46 AM
95_Blazer
Dec 6, 2007 09:44 AM
Deezy
Oct 25, 2007 08:58 PM
