abs light coming on
Old Mar 28, 2007 | 02:51 PM
dusted800's Avatar
dusted800 is an unknown quantity at this point
Default abs light coming on
I have a 95 blazer that has the abs light coming on whenever I get to approx 15 mph. I have searched past posts and have removed the rotors. I cannot find any bolts that hold the sensors in the hub. I can clean the ring with sandpaper as they are easy to get at, but what do you use on the sensors. can I just spray them with something? thanx. wnk.
Old Mar 28, 2007 | 03:19 PM
20Blazer00's Avatar
Default RE: abs light coming on
You might have to remove the brake calipers to get to them in the front. They have a single 10mm bolt holding them to the back side of the front hubs, remove them and clean the mounting surface to remove rust. Then re-install them...
Old Mar 28, 2007 | 06:28 PM
dusted800's Avatar
I have removed the brake caliper and still do not see where they are mounted, do they have a shield of some kind over them covering this bolt? wnk.
Athlon2012
Nov 1, 2014 03:50 PM
Tinted
Mar 15, 2012 02:56 PM
damageinc98
Jul 12, 2010 10:47 PM
stormshadow1
Apr 23, 2009 09:46 AM
zerokarma
Dec 6, 2007 01:55 PM
