ABS Light, Speedometer Malfunction, Transmission wont shift past 2nd gear.
Old Apr 11, 2017 | 12:33 PM
  #31
Cody Cochran's Avatar
Cody Cochran is on a distinguished road
I am having a problem my abs light is on and speedo does not work and will not shift I have replaced the vss and the abs modlue also I had it checked with a snap on scanner and the abs will not communicate. This is on a 98 Yukon 4x4
Old Sep 24, 2017 | 08:53 AM
  #32
chiggenbotham420's Avatar
chiggenbotham420 is on a distinguished road
I got a 2001 blazer transmission slipping but only when gets hot. it has 4l60e in it. But when it starts to slip bad rpm goes up to 4. I shut the blazer off in N then start it right back up and it act likes its normal for a mile or two longer. I got the 4x4 motor out of my blazer. I need truly some help on this.
Old Oct 5, 2017 | 05:25 PM
  #33
Crystal Dawn Stewart's Avatar
Crystal Dawn Stewart is on a distinguished road
This is a really old post, but I'm hoping someone may see my post. Does anyone have a picture of the VSS part that needs to be replaced? I've bought 2 different parts (that the store said was correct) and neither has worked. HELP
Old Oct 6, 2017 | 05:21 PM
  #34
John Sneathen's Avatar
John Sneathen is on a distinguished road
Unhappy same problems only different
I had replaced number 3 sensor when I started having this problem last year and it cleared up and started working again, replaced number 3 because the info I was given said that was the vss, but, now it started doing it again, I had no idea, there is actually 3 of the same sensor type, in three different locations until I went through the pain of taking the transfer case out of my 2000 lt blazer, so, was wondering if I should just buy 2 more sensors and replace the two I haven't already, and place the transfer case back, hoping that the problem is resolved, or just buy another transfer case and put in.
Old Oct 6, 2017 | 06:10 PM
  #35
if you go through the feeds there is a diagram that shows you where the speed sensor is, it's actually on the back top drivers side of the transfer case, most of them are a black plastic sensor and they screw into the case and it is a two pin or two wire connector that goes to it
builder125
May 20, 2013 06:51 PM
barredjack
Mar 29, 2013 06:50 PM
lionel2
Mar 21, 2011 01:55 PM
texas4x4blaze
Jul 16, 2010 08:51 PM
dimone545
Sep 3, 2008 08:25 AM
