ABS light and strange noise
Old Dec 6, 2006 | 07:52 PM
ckirv's Avatar
ckirv is an unknown quantity at this point
Default ABS light and strange noise
2001 Blazer
My ABS light stays on all of a sudden and the part next to the master cylinder (silver with brake lines on drivers side corner) is making a grinding noise even after turning off the engine. I had to remove the ABS fuse from under the hood to get the noise to stop. What is this part and what do I need to do? Brakes work fine. Any suggestions would be appreciated.
Old Dec 6, 2006 | 08:51 PM
rooster's Avatar
rooster is an unknown quantity at this point
Default RE: ABS light and strange noise
that part is known as the control module if its adjacent to the master cyl which means u have rear wheel anti-lock(rwal), if its underneath the cyl then u have 4 wheel anti-lock(4wal), which then its a electro-hydraulic unit. when ur abs light goes on then there is a code stored, so u should have it scanned. im not sure what makes up the module but it controls the pressure in the line and there is also a dump/isolation valve attached to the module that might be bad. but scan for codes first,
Old Dec 7, 2006 | 01:33 AM
Chevy Lover's Avatar
I don't think it's possible to diagnose that problem without the use of a scanner.
Old Dec 7, 2006 | 03:17 PM
ckirv's Avatar
thanks guys.....I'll have it scanned and get back!
steve72
Sep 1, 2014 11:41 PM
damageinc98
Jul 12, 2010 10:47 PM
ExplicitYourSelf
Aug 12, 2009 02:20 PM
stormshadow1
Apr 23, 2009 09:46 AM
Deezy
Oct 25, 2007 08:58 PM
