ABS Light on then off with 4x4
Old Dec 23, 2008 | 06:18 PM
cr8390's Avatar
cr8390 is an unknown quantity at this point
Default ABS Light on then off with 4x4
Hey everyone i just noticed tonight that my abs light comes on and stays on, but i figured out that if i engage ymy 4x4 high then back to 2 wheel then turn the truck off and back on it the light dosent turn on anymore until like the next day or so. Any suggestion??
Thanks
By the way 1999 LS 4X4 82,000 miles replaced bothfront wheel bearings about 5000 miles ago.
Old Dec 23, 2008 | 08:28 PM
Peru Motors's Avatar
Peru Motors is an unknown quantity at this point
Default RE: ABS Light on then off with 4x4
must be intermittent but...if the light is or has been on you have a current or history code. Either scan it and let us know the codes or have it scanned....has to be something. JP
Old Dec 23, 2008 | 09:37 PM
cr8390's Avatar
alright well i dont know when im gonna be able to get it scanned but are there any other suggestions anyone can give me?
Old Dec 25, 2008 | 07:05 PM
cr8390's Avatar
bump bump
any 1 know?
Old Dec 25, 2008 | 08:17 PM
other the blindfolding yourself and stabbing in the dark.....Look at the ABS wire that was installed 5,000 miles ago-from your wheel bearing-running to the upper A frame finally to a connector on the frame. Look close at where the wire bolts with a clip to the A frame with a 10mm nut(out near wheel). I have had all kinds of trouble in the past, with aftermarket wheel bearings that WERE NOT Timkin bearings. If you used a Timkin(unless installed wrong) I doubt this is your problem. If you used any other bearing.....do look where I described. Other that....a visual look is about all you can do without a scan tool and that usually won't cut it. JP[&o]
Old Dec 25, 2008 | 08:23 PM
cr8390's Avatar
Ok i will do i did use a Timkin bearing by the way thanks so much
Old Dec 25, 2008 | 08:38 PM
If you used a Timkin-unless someone twisted the #*@& out of the wire, I doubt that the wire is your issue. I think that you'll ultimately have to have it scanned and either-a)have it fixed or b) gather the info given and report back the this site...There are so many things it could be...like going to the doctor and telling him that you don't feel good-what do I do Doc[&:]? JP
Old Dec 25, 2008 | 09:11 PM
cr8390's Avatar
lol ok well my dads gotta a scanner at his shop that he was gonna scan it with but he got in a little fight tonight so that went out the windows but ill let you know if i get any new info thanks
Patton
Mar 19, 2012 09:35 PM
Tinted
Mar 15, 2012 02:56 PM
cntryislandboy
Jan 25, 2010 04:42 PM
ExplicitYourSelf
Aug 12, 2009 02:20 PM
Seabbatical
Jul 11, 2009 02:30 AM
