Abs module
Old Jun 1, 2020 | 04:25 PM
Mdz320's Avatar
Mdz320 is on a distinguished road
Default Abs module
Can this be tested? Replacement tips, procedure? I was ut needs programmed. If so, how?
Old Jun 1, 2020 | 05:02 PM
93S10TahoeLT's Avatar
My ABS light has been on 99% of time driving too, possible module.. Interested in this thread.
Old Jun 1, 2020 | 05:52 PM
What's wrong with it?
Old Jun 1, 2020 | 05:59 PM
Mdz320's Avatar
Light on. Able to skid. Can't be read by code reader.
Old Jun 1, 2020 | 07:30 PM
Sounds like mine
OP, has the light ever gone off by itself while driving?
Old Jun 1, 2020 | 10:04 PM
I had an intermittent ABS light for well over a year. Performed a fix that has lasted over 3 years now with no issues.
Pulled the module off the top of the unit, carefully took a razor to the sealant holding the plastic cap on the top of it. After popping the cap off, just reflowed some of the solder joints inside. Then used clear RTV and sealed the cap back on and let it cure over night.
Reinstalled, the light never came back on, ABS works great (have tested it several times, both intentional and unintentional...)
I don't remember where I seen the info, but there's either a thread or a YouTube video out there of the procedure.
Old Jun 2, 2020 | 08:34 AM
eshaw's Avatar
What I usually find is the sensor in the wheel hub is the culprit for an ABS light being on. If they are removed and the ends cleaned the problem usually goes away. What makes you think that it's the module itself?
Old Jun 2, 2020 | 10:12 AM
This video may help us.
Old Jun 3, 2020 | 01:19 PM
Mdz320's Avatar
Mostly, because my scanner gets an error message. It can't connect to abs module.
Old Jun 25, 2020 | 05:47 PM
Czechman90's Avatar
Czechman90 is on a distinguished road
I have the same problem on my 96 blazer, it is on all the time but i have no problem with my brake system. I just put some black tape on the light area.. I know that's not good to do but when it drives you crazy it does it's job.
