ABS Relay 1999 S-10 Blazer
Old Sep 3, 2008 | 05:04 PM
dtetreau's Avatar
dtetreau is an unknown quantity at this point
Default ABS Relay 1999 S-10 Blazer
Does anybody know where the relay for the ABS module is located in a 1999 S-10 Blazer? Any help is greatly appreciated!
Thanks
Old Sep 3, 2008 | 05:06 PM
Default RE: ABS Relay 1999 S-10 Blazer
Under hood fuse block.
Old Sep 3, 2008 | 05:23 PM
dtetreau's Avatar
There is no relay under hood marked ABS!
Thanks
Old Sep 3, 2008 | 05:56 PM
Sorry, thought I saw fuse. There is no ABS relay, only the 60A fuse in the under hood fuse block.
Old Sep 3, 2008 | 09:12 PM
dtetreau's Avatar
There must be some sort of relay to power the ABS unit. I will try to trace the wires I guess.My problem is I have replaced both rear calipers, rotors, pads and hose to the calipers. I have bled the brakes many many times but I have no pedal. It may be a bad caliper on the right side. the parts store says reman could be defective.
Old Sep 3, 2008 | 09:17 PM
The EBCM (electronic brake control module) is powered through the 60A fuse in the underhood fuse block. All wiring diagrams I have only show the fuse. It is not something that is turned on and off by another system in the truck. It is self contained.
The master cylinder never went dry did it? Also, when you bled the rear brakes, did you always get consistent amounts of fluid out for each pedal push?
Old Sep 3, 2008 | 09:28 PM
dtetreau's Avatar
Not on the right side, that is why I suspect a faulty reman caliper. I am going to exchange it and try again hopefully thats it.
Thanks
Old Sep 5, 2008 | 05:40 PM
dtetreau's Avatar
It was bad caliper, Not only that but the exchange caliper was f-ed up too! I finally got one that was good God Bless Auto-Zone NOT!!!
pj5454302
Dec 12, 2009 08:20 PM
swallace8337
Sep 29, 2009 05:25 PM
Bodar
Jan 25, 2009 01:44 PM
Ronmacd
Dec 19, 2008 10:23 AM
bestes
May 31, 2008 03:16 PM
