ABS sensors
ABS sensors
Hey Good morning
I have 2 bad ABS sensors on my front wheels.
I know that I can just pull the fuse which I may end up doing however I would like to fix them permanently. Is it possible to just change the sensor and cable or does one have to change the entire hub. if the hub is the answer do I need a front wheel alignment afterwards.
The hubs themselves are a little under 180.00 CDN$ each
Thanks
Don
Thanks
Don
Hey Good morning
Thanks
Don
Thanks
Don
Thank you Les for the info. Worth giving it a shot. Also saw a couple of videos on YouTube, does not look too hard
Think I will order 2 sensors from RockAuto and replace them in the spring
Thanks again
Thanks again
Resistance is futile!
They generate an AC voltage when you spin the wheel. See attached TSB for testing.
I understand ...
but I mean the resistance of the ABS sensor to determine if it is working ... the ABS indicator on the cluster lights up. the sensor looks like new - maybe it's faulty. maybe it is too far from the rack - what is the distance between the sensor and the gear?
I understand ...
OK - I see that English may be a second language for you (Poland). I'll try to explain more precisely.
The functional test for the sensor is to check for more than 350 AC millivolts output with a digital volt-ohm meter, while rotating the tire (not resistance measurement).
Good luck and best wishes for a successful repair. If you would like additional help to repair your ABS, I invite you to start your own thread on the topic.
I replaced just the sensor on my 04 after the wire chaffed through against the upper control arm... I actually used the sensor from an early 2000's Silverado from the junk yard. Same sensor head and same plug, the wire is just about 6" longer, which I actually liked because it let me route it a little different and out of the way of anything that will chafe on it again. All I had to do was transfer the little mounting brackets/tabs from the Blazer one over to it. It's been on it for about 4 years now and hasn't given me an issue since.
FYI, pulling your ABS fuse disables your cruise control lol
